Anyone know the number for the vag tool needed to do the rear brakes?
i mean to change the rear brakes... from my understanding the generic cube that you can buy from auto stores needs to be modified to work and that it isn't exactly the right tool, and there is a special vag tool for the job.
Modifying the cube is not that big of a deal. And apparently it works just fine. There are probably better tools, but for something you're rarely going to use, I just assume spend $10 on the little cube. I'm willing to bet the VAG "special tool" is going to cost a bit more. Good luck
Andy<ul><li><a href="https://forums.audiworld.com/a4/msgs/249321.phtml">Andy H. shows how to modify the cube.</a></li></ul>
Looks like one of the brake tools at this place might work. Also try www.zelenda.com as well.
Good luck!
Andy<ul><li><a href="http://www.samstagsales.com/vwaudi.htm#brake">http://www.samstagsales.com/vwaudi.htm#brake</a</li></ul>
Good luck!
so funny you just posted this since i just called zelenda and the tool # 3272 that i need is $135 shipped. LOL! I guess i will learn not to be so ****. Time to break out the ole dremel. How hard/easy is this cube tool work once it is modified?
TIA
TIA
I thought you were just about to tell me "so funny because I just called Zelenda and the tool is only $30!!" I've not yet used the cube, planning to do my rear pads/rotors any day now. I'll let you know if I get to it before you do. Good luck
Andy
Andy
...a little more refined than the $10 Lisle cube, and its got an Audi/VW adapter inside.<ul><li><a href="http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=46790">Brake Tool</a></li></ul>
