Anyone know the part number for the center caps for..
...the 16x7 Swing Wheel? I need to replace the VW center caps that came with the wheels I bought for Audi center caps.
you already have what you're looking for. VW puts metalic "stickers" on top of audi caps. peal the stickers off and you'll see the 4 rings. you'll will most likely need to have them painted b/c the finish will be not so good.
Is there an easy way to pop the center caps off the wheels w/o removing the wheels from the car? The tolerance between the wheels and the caps is very tight.
be carefull taking off the stickers. the edges are very sharp and will cut you like razors if you don't take your time. once you have a small area pealed back, pull off slowly with pliers. if you wear garden/utility gloves, you'll have zero issues
...you are right, the stickers are sharp. Pliers are a good idea. I think I may be able to use a Dremel tool to clean up the caps after I get the VW logos off.
Sleep well...
Sleep well...
<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&engine=1.8T&mod el=B5%20A4&submodel=Quattro&category=Drive train&subcategory=Wheels">http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&
byranovic
Wheels & Tires Discussion
06-03-2017 12:50 PM
auditonyusa
04-05-2005 08:51 PM
Mooney
07-30-2001 06:16 PM
