Anyone knows anything about code P0411?
Old 05-06-2008, 12:32 PM
  #11
@wesome's Avatar
im curious: how much did you sell the suspension for?
Old 05-06-2008, 12:39 PM
  #12
Banned
ModifiedA4's Avatar
Default the official factory explaination
as found in the archives by searching, posted by myself, countless time.
<b>Audi Tech Tip</b>
<i>"In the event you have an A4 1.8T with engine code ATW with the DTC of 16795 - Secondary Air Injection system, Incorrect flow Detected, a leaking Combination valve could be the problem. A leaking valve causes exhaust gas to enter the secondary air system. The water from exhaust condensation travels through the entire secondary air injection system and if the temperature drops below 0 degrees Celsius the water will freeze. In most cases the water causes the air pump to corrode. Inspecting the combination valve will reveal the problem. If the Intake side of the valve is black, exhaust has entered the secondary air injection system."
</i>
also, is this you?
<img src="http://pictureposter.audiworld.com/147863/april_08_113.jpg">
Old 05-06-2008, 12:57 PM
  #13
New Member
Coryvw's Avatar
Default Re: I DO CHECK THE VACUUM HOSES AT THE COMBI VALVE!!!!!!!!!!!!!OMGROFLAMOHAHAHHAHAHAHAHA
I took it to the dealer when it first gave me tnis reading back when i got the car...and they said it was two of the hoses and replaced them and now is back again, so i know is not the hose, they are new....
Thank you for your imput
Old 05-06-2008, 01:01 PM
  #14
New Member
Coryvw's Avatar
Default Re: Hey! It's true. I bet there's a vacuum leak in the hose leading to the combi valve.
they have been changed recently....in December.
Old 05-06-2008, 01:03 PM
  #15
Keeper of the Cash
Nate (ETKA+Scumbag)'s Avatar
Default TJ...
Actually, and I can prove this when I get home.
I didn't sell it and I won't. The shocks have been uncompressed too long and I in good mind would not sell them to someone.
I won't use them for the same reason, plus the time spent on installing them just is not economical and could be put towards a coilover setup.
The set is up in my attic, same spot it's been since last April.
Sad, I know.
I just wanted to make a point. The point being I'm still believed and listened to on the forum.
Old 05-06-2008, 01:04 PM
  #16
New Member
Coryvw's Avatar
Default Re: I'd check them anyway.
okay, i will......thank you.
Old 05-06-2008, 01:18 PM
  #17
@wesome's Avatar
Default you need to have your internet ego confirmed?
what aspect?
the one that you can't wrench on a car?
the one that you put stickers on your car for mods you don't have?
the one that you lack experience and try to make up for it by being a keyboard lackey?
the one that you start internet drama just to make sure people still recognize that you are "believe and listened" to on the forum?
Nate you really should recognize that this is just the internet; it shouldn't impact your life in a significant way... yet it really seems it does
you're basically the mbtb of a4 b5...
Old 05-06-2008, 01:27 PM
  #18
@wesome's Avatar
Default blech... a self response
Nate this is a forum for a4 b5 discussion/debate etc.
you're just trying to start drama to make the forum more "exciting"
it's ****ing lame
when you left, it was very nice, the forum moved along smoothly with normal discussion and good debate
now that you're back
well look... you're just trying to start ghey internet flamer attention.
Old 05-06-2008, 03:11 PM
  #19
Head Cat Herder
Kris Hansen's Avatar
??? That makes no difference by the way.
Old 05-06-2008, 05:00 PM
  #20
@wesome's Avatar
Default i r linking
<ul><li><a href="https://forums.audiworld.com/a4/msgs/2810433.phtml">click link in that post</a></li></ul>
audionlineparts
A7
09-09-2016 08:43 AM
SForked
Mid Atlantic Discussion
12-21-2008 11:53 AM
Joey T
07-29-2005 12:45 PM
CURSH[silverbullet]
04-22-2005 08:22 AM
Quick Reply: Anyone knows anything about code P0411?
