Anyone replace thier hub/bearing assembly?
Did you do it yourself? Would you do it yourself? Any tips, tricks, or is that something that you would let the dealer do?
You also need a hub puller to do the disassembly. its not really that hard as long as you have the right "pushers" to install the bearings. If you dont have access to a good size press, I think the one I used was 10 ton, I wouldn't attempt it. I dont really have any tips. Push em out, push em in.
I don't know how comfortable you are with doing things yourself. I'd do it myself again if I had to, even though it was a major PITA. The bolt connecting the two upper links was welded with rust to the housing and I could not get it out after several days of trying different things. Heat would have helped.
Pushbutton_auto
11-13-2008 03:43 PM
sjthomas
04-21-2007 06:45 PM
Heed
02-29-2004 04:12 PM
A4inMD
06-25-2002 03:55 AM
