APIKOL rear diff mount installed
#11
<center><img src="http://i21.tinypic.com/2r6nq6u.jpg"></center><p>1)fuel injector spray pattern
2)fuel pressures
3)injector seals(highly recommend this one)
4)cam to crank timing
5)plugs
6)clean out thottle body
7)check for vaccum leaks and clogged crankcase vent hoses & pcv
Balance issues:
1)faulty or failing pressure plate
2)flywheel failing or needs to be retorqued
I could go on, but you get the idea. That Apikol mount was one of the best mods done to our car. You might consider doing the Stern rear diff bracket bushings.
2)fuel pressures
5)plugs
Balance issues:
#15
<center><img src="http://i32.tinypic.com/11k8kza.jpg"></center><p>When you say something is "harsh", I take it literally. I'm not a fan of Stern's mount donut but their rear diff bracket bushings are a no-brainer. Pic of them pressed in a spare bracket I had around.
#19
one of top notch manufacturing and attention to detail. These were only released last year although I think they will do great.
#20
for all of the thousands of cars made are identical. You can use this to sort of fine tune though possibly and make sure everything is lining up properly.
