APR Stage IV Kit??
APR Stage IV Kit??
I heard that APR was developing a stage IV kit for the a4 1.8T; does anyone know when that kit might be available and if so, what some specifics about it are (parts, HP, torque, etc.)? Thanks...
Back in the day the rumor was it was a 10k kit...
with a fully built 2.0L putting out ~400hp. I assume it would have been a strengtened bottom end, pistons, springs, valve work, PnP, cam, the whole affair, and at 10k obviously a serious project. Never really materialized since im sure the market would only be Dmak and a couple other guys I suspect when the FMIC gets done that SIII+ will get re-introduced with more power to place it around 350hp.
BUT, PES will do a built motor for you, Ryann and CMH have gone down that path, you can email Ryann, it's surprisingly affordable to build yourself a "built" 2.0L that can take ~30psi of boost and make mid-300's or higher HP. ALso, TDL racing in Warren, MI does good work, im sure they can do a built motor for you.
A couple other guys to query; Xr4tic also knows a bit about building up an engine, he is a good resource. Billy1.8T on VWvortex has lots of info as well.
Cheers,
Sameer
Cheers,
Sameer
violinguy
14
01-06-2004 05:45 AM
Nogaro S4
06-23-2002 03:48 PM
