ATP Findings on my Fuel Pump
Customer Problem
Statement:
Customer suspects fuel pump has bad check valve and needs to send back for inspection
Pre-disassembly
Inspection:
Only base fuel pump received, not fuel pump kit as stated on order 18849, also missing filter sock and outlet nipple
Level 1 Disassembly:
Tested base fuel pump and holds residual pressure of 55 psi without issue after 48 hours.
Level 2 Disassembly:
Customer may have had leak at the lip due to dislodged (missing) outlet nipple during installation, but check valve holds pressure fine.
Finding:
Cause: Install issue.
Customer already bought new base pump (not kit). Give option to send working pump back to customer or issue 50% courtesy credit against new base pump purchase already made.
Statement:
Pre-disassembly
Inspection:
Finding:
tozoM8
07-15-2008 07:12 PM
eurovan5150
Audi 100 / A6 (C4 Platform)
09-21-2005 01:01 PM
LarryF_in_Ca
01-01-2005 10:22 PM
ISRAEL-TT
01-03-2004 12:42 AM
