audi 96 a4 coil packs
I'm new to working on Audi and VW. But I'm changing the.coil packs and I'm trying to figure out if there are packs for each cylinder or not I seen them on rock auto but I'm not sure if its just a bracket does it come all in one or seperate. Thanx
Yeah its just telling me three cylinders are mis firing I think air is leaking in which makes it dump more fuel but when I press the gas sometimes u can tell something is wrong like all the power isn't there so I was simply going to replace everything and the o2 sensor
As you have seen here, the coil packs almost never go bad. My originals have 235K miles on them, plus I've never even had to change the ignition wire set. Just replacing "everything" is not a methodical approach, but maybe you have plenty of spare time and money.
FYI, there are three coils, one each for two cylinders. This is a "waste spark" arrangement, so you have two spark plugs firing at the same time, but only one lighting the fuel/air mixture.
Is this a 4 or 6 cylinder engine? 4 cyl 1.8T has coil packs on top of each cylinder. If its a 2.8 V6 you have wires that go to a single bunch of coils. If I remember correctly each coil supports 2 wires.
Jason
Jason
wishibroughtaclk
11-01-2015 03:42 AM
CPM, here's what Audi emailed me back as a response. I'm sure you've seen the same, but here goes...
Projekt 8E
12-31-2002 09:18 AM
