Audi A4 1996 Audio
Hi,
My car has a blaupunct stereo fitted which does not look like the original. I would prefer to use an original as it would have the red display and be more in keeping with the rest of the dash. Which radio works in this model. Also I would like to add a 6 deck cd player. Would they be compatible the standard head unit
Regards
Tom
Regards
Tom
You should be able to pick up a head unit cheap (make sure you get the anti theft code) but the special changer is difficult to find and fairly expensive even used. (No aftermarket unit will work and there are no adapters to make it work)
Thanks.
At least I know where I stand. If I was to buy a head unit which would have the red lighting as per the original could I fit a unit from a later Audi that would be easier to interface to a sony cd changer.
Regards
Tom
Regards
Tom
... Maybe you should look at newer alternatives.
I have the Delta CC with a changer and I haven't used the changer since I connected my iPod.
What are the options for newer systems. I want the retain the red display which I think looks good
Regards
Tom
Regards
Tom
AUDIOZ A4
06-16-2003 06:15 AM
zebedie
06-09-2002 01:20 PM
a4forme
01-02-2002 04:42 PM
