AUDI A4 2.8 V6 QUATTRO TURBO PROJECT!!!
#21
also i want fuel controller so i can make it run rich instead of lean and melting the weak internals that the glorious 2.7t doesnt have, but i like a car that gives a challenge something hard to work on, and one that everybody slags off untill it pins you in the seat lol
#23
and what is "way more" power? that's simply not true.
a turbo does not drain as much power as a S/C, but turbo isn't free either - it restricts the flow of the exhaust.
fact is, supercharged systems are simpler to maintain and adjust than turbos. power returns are very similar, although they have different properties.
#24
Most of that +5000HP comes from burning nitromethane, not from boost. Typical is about 45psi, or 3bar, not nearly enough to reach those power levels from a 500inch motor. The advantage turbos might have is a softer power build, since tire spin is the main issue all the way down the track. But it's all highly spec'd at this point and is what it is.
#25
#26
thanks that is true, and in the spirit of a cheap build ive ended up with fuel controller but the wiring diagram is in japanese, any one fluent lol???
PassatKidfrombucket (01-24-2022)
#28
Hay am a new user an am looking to do the same built 2.8 twin turbo set up but am going to rebuild the engine metal gasket performance seals
hone the block down piston rings remove any ridge basic engine work
