audi a4 b5 wont start up ?
hi guys how you doing ?
my car wont start at all after i changed the cam chain tensioner
and i done it perfectly the marks all meets on the cam - cam caps and the marks on the chain and i count 16 rols between the cams and cam caps marks so i think every thing is OK
but the engine wont start at all so i asked some people about that and they all agree about one thing is possible which is the hydraulic leftrs all are Extended so its must be there is leaking on The combustion chamber so they told me i have to chec if there is leaking by removing the spark plugs and turn the cam to ensure the valve is closed and stik a tube in spark plug whole and start to Blowing air in The combustion chamber so i i did for all 4 pistons combustion chambers and all leaks out ........ i giv up a little help ??????????
People are telling you the hydraulic "leftrs" are Extended? Forget them, get your advice from AudiWorld!
You need compression, the right amount of fuel, and a spark at the correct time.
i just talked to a guy that said he had trouble finding engine mountings for his A4 in Zimbabwe. Am i the only one that thinks he is really missing the problem as to why he had trouble finding them? get back to me on this people. i can't be the only one laughing.
i removed the engine cylinder head To make sure the valves are in good shape and check it out so i tested the valves by And set up the cylinder head upside down So that the direction of the valves are faceing me then i Poured some gasoline Overhead the valves as we know Supposed to be no Leaking through the valves
but my valves are leaking so that is way the engine wont start up i think so Valves did not strik the engine pistons the valves are fine pistons are fine 2 the cylinders are fine alsow
so what i am going to do i will take out the valves to clean it up and i will put them back in and make sure there is no leak at all
so there wgat i a going to do :
1 - clean the whole cylinder head
2 - clean the cam shafts and cam shaft caps
3 - clean the leftrs
4 - clean the valves
and this opration if it goes fine its will add some power to the engine
i will add some pics when i am done when its ready !!!!!!!!!!
yes its crazy to what happened to me the car was running just fine till we changed the cam chain tensioner and its wont start at all !!!!!!!!!!!!! i dont know why so i start testing all Suspect parts has a link with intake and Exhaust port
Did you pull and codes prior to disassembly? Verify chain and belt timing? Compression or leak-down test?
ok i had an compression issue with the engine the head cylinder has 5v per cylinder and they all leaking out i removed the cams to ensure that the valves must be closed perfectly , to make the compression In the combustion chamber so is there any leak in combustion chamber there will be no compression Because the Expanding gases forc the piston to move down word so if the gases can be leaked out of combustion chamber its will be no compression i think !
