AudiRcr...
I have a 1996 and my tail lights swapped in with out any re-wiring at all. (However someone recently tried to do it with his 98 and had to do some re-wiring.) I would assume that the 96 and 97 should be the same becuase we have the same style tail lights.
I got my 2000/2001 style tail lights from someone on audiworld. They did not give me the bulb holders, so I had to get them from the dealer. Do you have both the bulb holders and the tail lights themselves?
Here is what I did:
Unscrew the 2 plugs that are in the interior of the trunk. The grey trunk lining will then pull out a little bit. Then use pliers or a wrench if you have one to unscew the 4 scews holding the lights in. Then unplug the lights from the cord. Be gentle in doing this. Next, the tail lights should pop right out. Be careful not to loose the screws, they are small. Then, the plastic piece on the tail lights pops out. This may be hard at first, it just takes patience.
After dismounting, then just add the plastic piece to the new lights, put the lights in, connect the wire and put the four screws in. When putting the blubs in, make sure you put the one with 2 little bars on the bottom one, that is your brake light. Also, there is no bulb on the very top right light, becuase there is no fog there in the US.
Hopefully this will workout well for you as it did for me and you will not have to do any re-wiring. Just drop me an email if you have any trouble im around all the time.
Here is what I did:
Yeah, I have the everything, bulbs, housing, lgihts etc. So, it should just be a direct swap, right? That makes sense because the 99' lights have the reverse light high and both the 97 and 01 have it low. Thanks for the help, I appreciate it. Also, I sent an e-mail to you, so disregard it.
Passenger side: switch #4 and #6
Driver side: switch #1 and #3
The only reason you might need to switch the wires is because (for me at least) my blinker was the back up light and back up light was my blinker. I have a '96, and got my tail lights and bulb holders from a guy on the forum, and a junkyard.
Im@wesome~ out!
04-29-2005 12:40 PM
airmax617
03-26-2004 03:45 PM
podendum
10-10-2001 08:35 AM
