Autometer Gauge --- Should I get 20psi or 30psi?(more)
AudiWorld Expert
I have Apr EMCS V.3, boost shouldn't go over 20, but would a 30 be more accurate?
Any advice, ideas?
TIA<p><A href="http://registry.audiworld.com/audi/registry/details.asp?car=4586">
<img SRC="http://members.bellatlantic.net/~theos2/signature.jpg"BORDER=0></a>
Any advice, ideas?
I got the 20 PSI as I can see the graduations easier
If I had an UrQ which went to over 20 psi, I would have the 30, but since I have a 1 bar chip, I figger the boost spikes won't go over 20 for very long...
Let us know how the install goes. Min'e on order from carparts.com, ships the 15th... Grr.<p>99.5 1.8Tqms Laser Red
97 Jetta ]I[ 2.0 GL Gold
88 ZX-10 Red/Black
88 ZX-10 Red/Black
I'd get the 20psi gauge. (more)
Since the boost is only about 15-17psi you would be using a greater percentage of the gauge's sweep with the 20psi gauge. Therefore the 20psi guage should be more accurate than the 30psi gauge.
I would get a 25 or 30 psi unit..
A 20 psi unit will be at its far end of the scale. You get more resolution with a 25 or 30 psi unit. In the summer you may see spikes higher than 20.
There are many good units out there. I am using a www.westach.com FAA gauge now. Its works well and was cheap. It is 30-30 vac-boost.
I ordered the VDO kit from AWE. It arrived yesterday. Man, it looks nice. I cant wait to install it. The VDO nightvision gauge goes to 25 psi which is still high enough for me.
I allso recommend that you get a Gauge with Vac. The car is in Vac most of the time. Its great for watching your economy.
Clark<p><img src=http://pictureposter.audiworld.com/AudiWorldPics/2000/civic.JPG>
AudiWorld Expert
Do you have a pic of the VDO? Is it mechanical? Cost?
I agree. Mine goes to 15...not enough. The new Autometer I'm getting goes to 30psi.
<p>Cy...Pearl '97 1.8TQMS, APRv3.1, UUC, Neuspeed, H&R Sport, Bilstein, AEZ Bimos, AVS Sports, ATE Powerdisc, Mintex, Valvoline SynPower, Mobil 1, Autometer, K&N, Air Box Mod, Aluminum Trim...63.6K and counting.
