Autotrans Fluid check? A4
To check ATF level, Run car until trans pan is warm to touch. Without shutting the engine off and gear selector in P, take drain plug off with a big 17mm(?) hex. If ATF is dripping out a bit, then you are fine.
... amounts to getting the car to correct temperature and fingering the hole (yes thats what I said).
Put you finger in the fill hole and see how far up the fluid is to the top of the lip.
