Aux Electric fan loose/vibrating. What could it be? Can the fan be tightened?
<center><img src="http://www.autohausaz.com/secure/PartImages/8D0959455C.jpg"></center><p>
It's as if the bearings(if there are any) have worn out and it's causing the fan blade assy to be loose on it's spindle. Main q is if that can be fixed, or if the fan has to be replaced.
Try removing the assy, and there is a very small nut which holds the fan onto a shaft. Try tightening this nut and see if that fixes it. If not they are only $150 or so and DIY.
I may just leave it out if it can't be fixed, cold enough here that I won't overheat anyway.
