Back to square one with my 2.0 stroker project.
#11
I went with the AEB block w/ ABA crank, and having known what I know now, I would have went w/ full ABA.
I do not like having to grind the cylinder walls, or the oil squirter for cyl #4 (with the spacer, it comes really close to the 60-2 wheel) The R/S ratio is not ideal either.
my machine shop said I was crazy to cut the gear down on the oil pump to clear #4 rod as well, they swear it will fail, hopefully it won't.
Lesson learned.
Lesson learned.
#13
2.0L. You can just drop in the mk4 crank or have the proper gear pressed on the euro B6 2.0TFSI crank (and a bore of course). Just spitting out what I read at the "other place". Any reasons why not an AWM/06A??
Half way down the first post..."Now on the 06A block..."<ul><li><a href="http://www.audizine.com/forum/showthread.php?t=188078">Sorry for linking to the "other place"</a></li></ul>
#14
More of a hassle than I want to deal with.
Honestly, I don't see why the ABA would make such a better platform; people have been stuffing 92.8mm cranks in 058 blocks since VW rolled out the 2.0 16v in 1990. It's a proven configuration as far as I'm concerned.
#15
begin with? I guess I should have been more clear. If your end goal is to build a 2.0L stroaker, why not start with an 06A if its so much "easier"?
#17
there is nothing wrong with that, especially with the power you are putting down. For higher HP applications, though, I'd go ABA for sure. And like you said, the rod:stroke ratio is better on an ABA...that is why I like it so much!
#20
It really doesnt breath well at higher rpm. Rod ratio is not that great. If you cant look at the specs on the 2 engines and see the difference and the advantages of the ABA then build what you need. You will essentially use a stock block and wont have to worry about cutting down **** to make it fit and work. Do what you want, I dont care, I wont be picking up the pieces. I did give you good advice if you want to build a STRONG engine tho.
