Is it bad to drive with a sticky thermostat?
#11
on backroads it goes down maybe 1 tick if that, and idle it stays dead center, doesn't sound to bad does it?
I will get it replaced or do the job when i come back after this weekend, ill prob have it done next weekend. But my main question was would it be ok to travel a 150-200 mile trip with this condition i just described? I figure it is ok because on the highway it stays dead center.
What do you think?
Thanks
What do you think?
Thanks
#14
about me going on a long trip with the conditions im seeing, whether it was safe or not.
#15
An thermostat that opens too early prevents the coolant from getting up to temp, which isn't detrimental.
#17
With both those parts the temp stays at the optimum position on the gauge, one hair to the left of dead center. Neuspeed sells quality thermostats too, they go the distance. I have used them in VW cars from when they first starting selling them.
J
J
#18
I agree, running a car with an open Tstat can cause what you are mentioning. But...running a car with a 180F stat and fan switch is just running the car 9F cooler, which is actually good for many vehicles including the A4 turbo. Point: A bit cooler is okay...but open Tstat is not.
J
J
#19
strangely I get 1 hair to the left on the stock 87C one so maybe i should just keep it in. Ill log the temps on a vag and see what it is.
#20
How do you know it's the thermostat and not the temperature sender? The temp senders go bad a lot. I just replaced mine in the '99 car. It has the old square blue type ($34 grrr) and not the rounded green type ($5).
