Barometric pressure sensor: what it is, where it is, what it does
Barometric Pressure Sensor F96
"The barometric pressure sensor informs the Motronic engine control module of the current barometric pressure. At altitudes above 3200 feet (low air pressure), the charge air pressure is reduced to avoid overreving of the turbocharger." (-as in stock k24)
"At altitudes above 10,000, the charge pressure control system is switched off." ( - you have boost still, but it's totally based oÂ*n baseline WG spring pressure)
"The barometric pressure sensor also influences cold starting at higher altitudes. The reason for this is to avoid starting problems (flooding) at extremely low temperatures and at high altitude."
Retrieved from:<ul><li><a href="http://here">http://www.s-cars.org/postnuke/modules.php?op=modload&name=News&file=arti cle&sid=116</a></li></ul>
Alex Brown
A4 (B7 Platform) Discussion
03-18-2012 11:03 PM
paulroad
04-22-2007 07:35 AM
KaMaKaZieP -ALUMIN8-
09-19-2005 12:16 PM
