Is it the battery ?
if your only showing 10v with the engine off. i'd say you have a dead cell. does the car run ok if you jump it? get a diehard, sears will test the whole system!
They test the battery under full load and will check the alternators ability to charge.You should be at 13-14 v initially on start up and as the battery is replenished that will drop off a volt or so.Sometimes a dead cell may cause that number to drop. Also are you reading the gauge voltage.Use a Digital Volt Meter to messure the actual voltage as your gauge could also be off.
RemoTT
04-26-2006 03:10 PM
KevinH
07-30-1999 01:18 AM
