Battery replacement experience
Old 02-05-2007, 07:48 PM
  #11
B5Davem's Avatar
Default Most batteries fail due to overcharging,heat or plate breakage from vibration.
I believe in the firewall position as opposed to domestic cars with battery closer to the engine , if all the charging system is working correct it can lead to longer battery life. Its still starting the car at -5 outside,my car for the past 3 years been always garaged before we bought my daughters car and now I'm stumped as to how much longer I can expect this with it in the weather. Hopefully at least until next year and then I'll replace it before winter then . It first hit the road in May 97 so its actually 10 years old this year ,which is amazing . I've never seen another make battery go more than 1-2 years past its rating .
Old 02-05-2007, 08:28 PM
  #12
Member
77'911's Avatar
Default a response...
CCA - Cold Cranking Amps
I've seen some oem batteries last 10+ years but that was very unusual. Batteries tend to like, even temps, regular cycling, and regular/proper maintenance. I look at batteries as very inexpensive maintenance and insurance. The quickest way to cook the exceedingly pricey alternators and starters(and flywheel teeth) in these(or any) cars is too keep a weak or failing battery in it. For $60+ dollars , it just is not worth taking the chance.
Old 02-05-2007, 08:45 PM
  #13
B5Davem's Avatar
Default Re: a response...I meant what is the CCA rating of the OE battery ,not the meaning.
I know what CCA means
Do you know what to suggest if someone brings in a battery core and you can smell sulfur?
Voltage regulator...I've had a 2 hour course on just batteries . ****Edit*** found in ETKA ...oe battery is 70AH/340A not that high..
<img src="http://pictureposter.audiworld.com/64191/ase_certified.jpg">
Old 02-06-2007, 06:27 AM
  #14
Clues's Avatar
Default Here's a laugher...
I replaced the oem battery in 11/02 with an Interstate Megatron. Friday morning it died. Jump-started it and drove 15 miles on the highway. Later that day I came out of a store and it was dead. Tow truck gave me a jump, waited while I drove around for 10 minutes and then we determined that it was not holding a charge. He had a replacement brought down from his garage (not Interstate) because I needed the car that night.
The battery is guaranteed for 72 months. In speaking with Interstate, their waranty only applies to the purchase of a replacement battery... So I am SOL beacause I already bought a replacement.
Old 02-06-2007, 02:39 PM
  #15
A4SilverT's Avatar
Default Did you consider that the Sears has a full 1 for 1 replacement warranty
for the first three years? And they honor it! I got a full replacement after a year.
Prorated warranties are junk even if they're honored. You get a prorated amount of what you paid for the old battery. Of course what they're selling now has gone up substantially in price. I guess it's better than nothing, but I'll take free replacement any day.
Denis Mitchell
Q7 MK 1 Discussion
04-06-2020 04:17 PM
audi620
09-24-2017 02:53 PM
ballfire
Q7 MK 1 Discussion
26
05-13-2013 07:13 AM
esanmiguel
10-17-2007 08:19 PM
A4_THOR
01-13-2004 11:39 AM
Quick Reply: Battery replacement experience
