Because it was just brought up, Here are my full alighnment specs:
If you see anything that just trows up a red flag let me know:
<i>Left Front</i>
camber: -1.1°
caster: 4.8°
toe: 0.30°
<i>Right Front</i>
camber: -1.3°
caster: 5.1°
toe: 0.28°
<i>Front</i>
cross camber: 0.3°
cross caster: -0.3°
total toe: 0.58°
<i>Left Rear</i>
camber: -1.3°
toe: 0.51°
<i>Right Rear</i>
camber: -1.5°
toe: 0.57°
<i>Rear</i>
total toe: 1.08°
thrust angle: -0.03°
<i>Left Front</i>
camber: -1.1°
caster: 4.8°
toe: 0.30°
<i>Right Front</i>
camber: -1.3°
caster: 5.1°
toe: 0.28°
<i>Front</i>
cross camber: 0.3°
cross caster: -0.3°
total toe: 0.58°
<i>Left Rear</i>
camber: -1.3°
toe: 0.51°
<i>Right Rear</i>
camber: -1.5°
toe: 0.57°
<i>Rear</i>
total toe: 1.08°
sitting really close to -1 degrees on all 4's seems to be alright. Although you may want to consider the K-Mac camber, I am just gunna install it to be safe.. but only on the fronts.
When you go from stock to aftermarket, the car typically gets lowered. By lowering the car you are adjusting the camber of the wheels, which is the degree to which the wheels are bent or straight. For instance, -1 degree camber would mean that particular wheel is leaning inwards (towards the car) by 1 degree.
You have way too much, especially in the rear. You'll be wearing the outside edges of your tires in no time.
Your camber is higher than stock, but it's not that bad. Not like Honda/Acura which can easily get over -2.0 degrees from lowering.
Your cross camber/caster values are pretty good. Even better considering there's nothing you can do about them with the factory adjusters.
Blue2
01-31-2007 12:34 PM
TwinTurboTerror
09-23-2006 08:58 AM
|skolnick
Audi Original "S" Cars
24
09-09-2005 06:05 PM
avdh
04-09-2002 09:37 PM
