Bentley manual requires CD in player to run...is there a way around that?
I'd like to copy the CD to the hard drive and have the app look to the harddrive instead of the CD rom to run it. Anyone know a hack for that?
Had to STFA with different parameters and finally found an answer<ul><li><a href="https://forums.audiworld.com/vag/msgs/44.phtml">https://forums.audiworld.com/vag/msgs/44.phtml</a></li></ul>
if you load the app to C:, the data needs to be in D:. I struggled with this long long ago, and that's what I found.
With the new bentley (the latest version) to get around the one pc only thing, there is a way, but I'm not getting into it here.
I installed everything on C drive.
The trick was to install the cd's entire contents to c:\
edit the cd.txt file to say C: instead of D: (which is my cd drive)
MainlandMig
01-12-2012 04:25 AM
exS4||wp0ZZZ
02-17-2006 03:39 PM
Jeff Vader - boscoj
VAG-COM Discussion
14
03-14-2003 10:02 AM
tberry
08-19-2002 02:27 PM
