Blackstone oil report: would it indicate sludge?
<center><img src="http://pictureposter.audiworld.com/102074/blackstone.jpg"></center><p>Doing oil changes with Mobil 10w40 every 5 - 6k mi. Oil pressure light has come on 2x in 1000 miles.
Would the blackstone report done about 10k mi ago have indicated sludge?
I have a new pressure sensor & oil pump that just arrived via UPS. I definitely have a coolant leak somewhere to find this weekend.
Following sequence of events:
1/3/2006
76,634 miles
Reman engine installed
6/8/2007
116,164 miles
40k miles on reman engine
10/12/2007
126,200 mi
Flashing Oil Pressure Light 3x
Coolant at minimum
Oil level fine
No DTCs
Oil Change
Coolant fill to max
10/25/2007
127,200 mi (+1000 mi)
Flashing Oil Pressure Light 1x
Coolant at minimum
Oil level fine
No DTCs
Coolant fill to max
1/3/2006
76,634 miles
6/8/2007
116,164 miles
10/12/2007
126,200 mi
Coolant at minimum
Oil level fine
No DTCs
Oil Change
Coolant fill to max
10/25/2007
Coolant at minimum
Oil level fine
No DTCs
Coolant fill to max
Keeper of the Cash
<center><img src="http://i7.photobucket.com/albums/y293/FastA4Turbo/audi/BlackstoneLabsOilReport8-15.jpg"></center><p>
may only have a bad oil pressure sensor. You might just swap the sensor first.
As for the coolant loss, don't fill to max because you're probably blowing it out the expansion tank while driving down the highway. Fill cold to min so that when hot, the coolant expands to max.
Jake_27
05-11-2007 04:58 PM
B5QShip
11
12-05-2006 05:46 PM
