blower motor/relay/switch??
#31
I just went through this my self and have fixed the problem. Mine at least. This was all very easy to DIY. The heat and A/C were not working at all. I could hear the A/C compressor turn on as well as see the idle RPMs adjust as it kicked on. So I knew that the compressor was not the problem. If you have the Solar power sunroof (hot weather package), I'll bet your problem is the same as mine. It was the Solar relay switch. (Called around to two Audi dealers in town and they both had it listed under different names, "Solar relay switch" and "sunroof control module". $70. Took off the under dash on the driver side. Five screws i think and had to pop off the little part above the steering wheel. Pulled out a Fuse like box that was clearly marked 385 in big white numbers. This is what you want to replace. Really easy and cheap. If you email me. i'll send photos.
Dan Reardon (02-25-2020)
#33
Blower Motor staying on
So I just noticed my blower is staying on after car is off in 2000 a6. Never new i had a solar sunroof until I unplugged the battery and the damn thing was still on. Kinda freaked me out. What would be causing blower to stay on? Also what is point of the solar sunroof? Does it help with fuel efficiency or anything?
dassub
07-22-2008 12:45 PM
TurboEnvy52
09-25-2005 05:43 PM
pedroskova
03-04-2003 01:33 PM
