Boost Gauge Install Questions
I'm planning on installing a boost gauge on my car and I have a couple of Qs. I can't find anything but plastic T connectors from hardware/automotive parts stores. Will the plastic be OK to use or should I use something like brass? The plastic ones I found didn't say what kind of plastic it is, nylon perhaps?
Also, I read from some personal websites that they used a silicone vacuum hose. Again, I can't find anything but a rubber vacuum hose.
I don't think there's a problem using a plastic T and a rubber hose, the air inlet temp shouldn't be that hot after coming off the intercooler, but I just wanted to make sure. Any thoughts?
Thanks,
Mark
99.5 1.8T QMSX APR
Thanks,
Mark
99.5 1.8T QMSX APR
about the hoses, nylon will work just fine, the only reason i can see for silicone hose is that is might be stiffer, it won't vary the boost at all.
PKBlu::E30 Hunt
07-23-2006 09:53 AM
CowboysRock
06-10-2004 01:08 PM
A42.0rgy
12-18-2002 04:11 AM
