Bose too muddy in bass I have the cure!!!!! (long)
Guest
Posts: n/a
I have been complaining about poor bass response about the stock bose. it hits hard but when you turn up the volume the sound gets distorted. The bose amp does a good job in producing clatiry but i often find my self switching from -2 to -4 in bass with my treb set at +3. i have blown 2 sets of speakers (the woofers in the rear deack) dealer switched them out 2 times already.
The problem: is the Bose amp. it tries to produce bass but it is underpowered. What causes speakers to blow in underpowered amp trying to produce stronger signals. the bose amp has a weird setting for the subs (stock 6.5") it is too muddy and the response is unpredictable.
The cure: add a single 2 channel amp for the rear speakers. I originaly purchased 2 IB 4 JL's to be installed with my Alpine MRV T503 amp. i just got done installing the amp (took a good day of work). i connected the amp to only the rear and adjusted the speaker levels. The amp i used has a built in crossover with a boost controll. this allows to fine tune what type of base you want. basically i tuned it to a point where i get nice low smooth bass. i nolonger have to run it at -2 or -4 mine is set at 0 with no problems of boomyness. if i want more boom just turn up the corssover or adjust the radio.
I would highly recomend getting an amp for the rear bose speakers they are good speakers if powered properly.
Guest
Posts: n/a
Unfortunately.....
The impedence of the bose speakers is not made for a normal amplifier to push. You risk damaging the speakers and the new amp running the speakers this way. Part of the "problem" with a bose car stereo is the amp is specific to the bose speakers and eq.
If this works for you good luck, unfortunately i forsee bad things for your equipment.
Darren
IASCA competitor and general car audio nut
`00 A4 this week perhaps??? woohooo
Darren
Guest
Posts: n/a
Current plans are....
to have a pair of kickpanels built ( i bought a tiptronic..no clutch ) ) for a pair of Image Dynamics Chameleons 6.5's.... one image dynamics IDQ12 and an Xtant604 off the stock head unit, removing the rear speakers totally.
Thats it as far as i know, i will NOT be doing a competition install in the audi, i think im done with all of that work and cost. I will still visit some of the shows, perhaps help judge but the audi will be just for me to be happy in.
algorithm
05-13-2002 08:29 AM
Bill In SoCal
04-03-2002 01:08 PM
idge
08-13-2001 04:59 AM
