Brake pad replacement %
At what percentage remaining should the front brake pads be replaced? (2000 A4 2.8Q)
It has about 36000 miles. At my last service about 1000 miles ago they were at 30% remaining. But they recently started squeaking a little when I brake, so I'm thinking they may be due.
What should I expect to pay for standard brakes? Any recomendations in San Francisco?
Thanks
Thanks
If you were truly at 30% 1000 miles ago...you've still got a long way to go before you need new pads. If you want to inspect the pads yourself, I would say below 2mm, start looking for new pads. Can't remember what the factor spec says....
around the same cost as OEM, but less dust... controversial "Better braking" with them.. but i think its the same
