Brakes and Rotors
Old 11-12-2003, 12:29 PM
New Member
A4B4U's Avatar
Default Brakes and Rotors
Hey all, my pads are down to like 2mm and the stealership says I have to replace the rotors as well. Can i just do the pads? Also, what pads and or rotors would ya'll recomend for a cheap upgrade? I was looking at the ECS Tuning drilled/slotteds.....
Thanks
Old 11-12-2003, 12:34 PM
Member
wnut's Avatar
Default the rotors are made to wear with the pads on these cars...
when it's time to change the pads, the rotors also need to be swapped.
ecs is a good alternative, also check with pure motorsports.
Old 11-12-2003, 12:35 PM
AudiWorld Expert
CraigB's Avatar
Default ECS slotted with Mintex pads. I have them on my GTI...
While you're at it, get 12.3" (A8) rotors for the front. Good bang for the buck upgrade.
Old 11-12-2003, 12:38 PM
odelay12v's Avatar
Default is it possible to use the a8 rotars and the a4 calipers???
partial a8 upgrade? or is that all there is to the upgrade??
Old 11-12-2003, 12:40 PM
Member
wnut's Avatar
Default ur going to need the TT calipers...
that IS the A8 upgrade. if you buy just the rotors i'd like to see how u get it to fit...
Old 11-12-2003, 12:41 PM
sbmellen's Avatar
Default On all rotors? My dealer did two sets of rear pads on same rotors...
...I am also planning on doing just a rear pad replacement on my APR Level II slotted rotors before getting new rotors back there. They're not eaten away or have build up on 'em, so I figure they're good for another set of rear pads...
Old 11-12-2003, 12:46 PM
odelay12v's Avatar
Default thanks that is why i was asking i have not been alble to compare them myself i believe you though..
tt calipers then it will some day be..
Old 11-12-2003, 12:49 PM
Member
wnut's Avatar
Default well...i'm not sure about the rears, but that's what they told me for the fronts.
people have gone with just swapping the pads and i havn't heard of any oem rotors cracking or falling apart (unlike some aftermarket rotors).
if your total bill goes above $500 i'd opt for the A8 kit. i got it and love it.
Old 11-12-2003, 12:54 PM
LaserK04's Avatar
Just get stock rotors and Hawk HPS pads......Mintex Redbox pads are NOT a performance "upgrade".....
Old 11-12-2003, 12:56 PM
Member
wnut's Avatar
Default cheap upgrade
that's what i read...
Quick Reply: Brakes and Rotors
