Buying a chipped ECU from someone
Hi,
My details:
2001 A4 1.8t 5spd FWD
Well, I am fairly new to the Audi scene. I did not really have plans to mod my car, I joined mainly for the how-to's and help with maintenance and repairs; overall care for my car. However, I came upon an opportunity to purchase a GIAC tuned ECU for my car for a pretty good deal; under $150. The guy said it is for a AWM motor for his old 2001 Audi A4 1.8t.
The owner says it was in his car but the car is sold and wants to get rid of the ECU. From what I've been reading the ECU's aren't all compatible with all cars. I have been reading around but I am not fairly confident in making a decision with the purchase. I guess I am looking to what I should consider with purchasing his ECU? I know that I should verify if his part number fits my car, but I am unsure how that's done. So any help would be greatly appreciated.
As for putting it in my car is it a direct plug and play or do I need to make the car learn something (I read something about that but was unclear of this tidbit)?
I have done some research but I feel I need a more direct and timely approach as time is of the essence; someone else locally might pick up the part. Thanks!
My details:
You have an immobilizer that is tied into the ECU. So you need to know somebody with VAG-Com and possibly a device to pull pin codes.
The ECU numbers should be checked. VW/Audi loves to have tons of different parts for different applications in the same car.
Most 2001 don't have immobilizer, very few made it into the US that way.
Check to see if you have the key symbol lighting up in your cluster, if it doesn't you don't have an immobilizer.
If you don't have immobilzer its an easy swap. You need to do a throttle body adaptation after you install the replacement ECU. Plan on upgrading the diverter valve also as the extra boost will probably overwhelm the old stock valve.
Anyways, I apologize for taking a long time to update. The guy keeps telling me "by the weekend I'll get the part from the shop." Apparently he's keeping it in a shop somewhere. So I'm just waiting on him to get it now so we can do a deal.
Thanks
GIAC chipped ECU Question
Is this a plug and play? Do I need to worry about the items above?
The chipped ecu was in a similar vehicle. 2000 A4 1.8l automatic.
Jeremy Baker
1.8T Discussion
10-01-2017 10:57 AM
AvantMnkyA4
10
11-14-2006 07:29 PM
reza
06-25-2001 09:12 AM
