A/C Condenser Fan Not Working!
Hey guys,
I have a 1999 A4 2.8 Quattro.
My A/C condenser fan is not working. I bought a new one and replaced it, thinking that it would fix the problem. I should have tested the old one first. Turns out both the fans are good! $70 down the drain. Oh well, you live and you learn.
Anyway, any advice on where to look next? It gets HOT in my car during the summer!
Keeper of the Cash
Check fuses, check the relay under the knee bolster, check wiring harness (brown round plug) next to ABS pump and power steering fluid tank. Multimeter is your best friend.
why should I check the power steering fluid for that? Funny you should mention that though... I am having MAJOR power steering PUMP issues since this winter when I busted my power steering hydraulic cooling line. I replaced it AND the pump. It worked for a while now its leaking again and another pump is blown!
oooo i gotcha, NEXT to the power steering fluid. Yea i tried grounding it at the harness and the fan works, but now im left wondering what else it could be. I cant figure out which fuse it is... Same with the relay
I have a manual for my car and I cant find it anywhere in there, even under the name "blower control module," or resistor. i cant find fuse either. I swear im not retarded! just having trouble with this lol. Thanks guys
