Caliper carrier torque?
What is the torque spec for the two 8 mm hex bolt on each of the front caliper carriers? Just did a rotor & pad change and wanted to make sure i torqued it correctly. Is it 92 ft lbs?
Just realized i made a mistake, the two bolts for the carrier are not 8 mm hex bolts, they are 17mm bolts. The 8mm/7mm hex bolts are the guide pins.
i was trying to refer to the carrier bolts not the guide pins (hex bolts). i mixed up the two for some reason when i initially posted this thread. Sorry for the confusion.
i know the guide pins should be far less than 92 ft lbs, i torqued the carrier at 92 ft lbs and the guide pins at 20ish ft lbs
Luxus Panzer
12v V6 Discussion
09-30-2006 05:49 PM
pro_mtn_biker
12-25-2003 06:46 PM
Mirror|rorriM
11-05-2001 03:41 PM
BigMouse
09-13-2001 02:41 PM
