Cam caps reinstallation sequence
I need to replace the crankcase oil seals and cam chain tensioner gasket on my 2000 A4 2.8 ATQ. I know the correct sequence for removing the cam caps, however i am unsure as to the sequence to put them back. Do i put them back in reverse order from that of removal or do i need to put them back in the same order as i removed them, e.g if say caps removal sequence was 1-2-3-4, should installation be 4-3-2-1 or 1-2-3-4?
https://www.audiworld.com/forums/sho...d.php?t=217844
Good Luck!
jamile222
09-29-2015 11:22 AM
