Camber kit?
Anyone one got a kit which make you able to adjust the camber on there A4?
I have fitted coilovers and have lowered it a fair bit. So i thing the camber will be way off.
I have had to tracking done but can not do the camber.
link.
http://www.k-mac.com/makes/audi.htm
has anyone got one of these kits? I think i will get my camber checked and see how far out it is.
Does anyone know what out camber should be set at?
I haven't installed them on the car yet though.
Lots of BMW guys seem to like the K-MAC stuff though.
-richard
-richard
If you have any thought that you will need to replace your upper control arms. Do the CPP kit.
By the time you buy new upper control arms plus the K-mac kit (also the labor is easier with the CPP) you will almost be there for the CPP kit that replaces your upper control arms.
The k-mac kit was kind of a pain. The factory upper control arms I had didn't work quite right. The hole where the steel sleved rubber bushing came out to make room for the k-mac bushing was too small for the k-mac kit. I had to enlarge the hole to make them fit, then press them in. I guess the bushings may fit differently depending on what control arms you have. So be aware of that. I think I heard someone say once the k-mac bushing was too small for the hole where the rubber bushing came out, you'd have to search on that.
Also FWIW...
My alignment shop had no issues getting the alignemt done with the kit installed.
<img src="http://pictureposter.audiworld.com/36175/03-25-05_1812.jpg">
Also FWIW...
