cams...pretty cheap...anyone have them?
#11
Maybe you should give Tony a call and see what he says about what sort of gains you could expect to see with cams+tune. You would also be able to get n75 code for your wastegate.
#14
you might not see full boost befor 3800rpm if you do it, but it will help top end.
I think with out lemmi winks, the ecu will have a fit.
#15
I'm just saying that a "big" enough turbo to warrant having something even crazier than those cams woud be like a 35R or something.
#18
I think all the dyno's say maybe 5 ft/lbs or so until around 4k rpms and then its up 10-15 ft/lbs for quite a bit. My setup is usually good for 20-30 whp tuned. I got 25 whp out of them at the same boost level, etc.
The biggest difference is the area below peak power. 6500+ rpm power is insanely higher, like 30-40 whp at 7 grand.
steveb56
04-11-2005 09:26 PM
BLKPERL
12-08-2001 01:19 PM
