can anyone recommend a good perch setting for the neu/bilstein sports?
i have mine set on one up from the middle on the fronts and one up from the bottom in the rear. now that it's done, i'd probably lower the front one perch to the middle so i can get that even, almost raked look. right now, it looks about even, almost saggy in the rear.
For a really low setting, set the front two notches up from the bottom, and the rear all the way at the bottom. That should put the front and back about even. The rear might need to be one notch up, depending on how the springs set. The bottom two notches on the rear shocks are small .5cm notches, as opposed to the others which are full 1cm notches, so they give you a bit of fine tuning room.
Hawaiiannights
08-01-2001 05:49 PM
A4agarwal
11-13-2000 07:58 PM
