Can anyone tell me the difference btw the K03 (stock), TAP K03 sport, K04 and K24 turbos!?!?
Guest
Posts: n/a
Re: Can anyone tell me the difference btw the K03 (stock), TAP K03 sport, K04 and K24 turbos!?!?
Okay, first off, there are two sides to a turbo, the turbine(hot) side, and compressor (cold) side.<br>K03 Sport is basically a K03 with a ported cold side for increased flow. The K04 is the same as the K03 except it has a slightly larger cold side for more flow. The K24 is a completely different turbo that is found on the previous generation S4/S6. It has a larger hot and cold side, as well as an external wastegate that controls boost alot more accurately than a K03's internal wastegate does.<p>Ned<p>
Guest
Posts: n/a
Flowrates (long)
Not offhand i dont. Ill look to gather some info.<p>But basically from experience, this is what you will see. I can only speak for the K03, K04 and K24. I do not know about the K03 sport since that is TAP's modification.<p>The standard K03 is good for more than 220hp, provided that the exhaust is changed. Without an exhaust, 205 is the most you should see.<p>The K04 is good for about 260hp, but i would never push it that far. Most people claim 225-235 with just a chip. I dont believe it. It is possible but it will not be reliable. a K04 with no changes to the exhaust will only net about 5-10hp over the K03. To push an honest 240hp you will need an exhaust, at least, 2 3/4" including modified cat, and a modified exhaust manifold. <p>The K24 is a gem of a turbo. Unfortunately, to upgrade an A4, this costs $ to do it right. The K24 will produce over 300hp with very little lag provided a proper exhaust manifold and exhaust system is used. <p>Oh, then you have the K27, good for 430hp. Mind you that the 24 and 27 require extensive modifications to your A4. Its not easy.<p>Ned
pic of K03 Sport and K04 side by side? k03 internals=k04 internals.But what is the dif then?housing?
beejohn
03-13-2005 05:39 PM
Stock Laser Red s4
11-28-2004 10:30 PM
NOLAN5162
Performance and Tuning
01-03-2004 09:35 PM
ALR
01-14-2002 08:32 PM
JCJiffy
01-22-2001 12:12 PM
