Can anyone tell me what relay switch is which?
Okay so my horn after I changed my ignition isn't working. I put the new ignition switch in and the horn worked. Just last week I had to use it because some tractor trailer cut me off on the high way and I got nothing. I went back through my complete job of putting the ignition switch in and nothing seemed to be out of place. Went to the horn with a volt meter and had a buddy hit the horn as I checked the voltage to the horn and I got nothing. I looked under neath the dash to try to find the relay switch and couldn't find the correct one. If anyone knows the correct switch that would be good. I also need to get some to VAG COM my car to get the air bag light out.
is it on the bottom row? also on the bracket closest to the seat? i pulled the plug to it from the back and tried jumping the wires and had no luck. burnt myself a few times but o well.
without having my car apart in front of me i'm giving you my best guess on how to locate it. if you know where the 75X terminal is, i'm pretty sure it's the relay directly above that.
see this page: http://www.google.com/imgres?imgurl=...26tbs%3Disch:1
for reference
for reference
even better is this one:
its the one marked 53 on the left
Troy H
Audi allroad
05-28-2003 06:08 AM
hoTTub
02-02-2001 09:43 AM
