Can bad spark plugs cause shruddering?
Step 1: Go to store and purchase a torque wrench that is good down to 22 ft-lbs, a spark plug socket that fits the replacement plugs you bought, and a 6 or 9" 3/8" drive extension.
be SURE they are torqued down correctly.... otherwise it will still do it. And if for some wierd reason that doesn't work... change the coilpacks.
For instance, the recommended plug seems to be the NGK BKR6E, which comes at a 0.032 gap. This is perfect for stock 1.8Ts. If you have a chip, you need to measure it out to a 0.028-0.030 gap (buy a tool that measures gap, and tap the plug tip against a counter or something and keep measuring). Otherwise, you might not get optimal performance.
If you're a 2.8, disregard everything I just said because I have no idea =P
[Arawan]
09-09-2004 07:00 PM
4showa
01-26-2004 08:41 PM
LeeTThal
01-25-2001 11:08 AM
