Can the BOSE sound system not be upgraded...?
I called Crutchfield.com and they told me that there is no way to upgrade the speakers or add subs to the 1996 BOSE system.
Is this true? Am I stuck with a sound system that cannot be upgraded in any way? I hope there is some way around this. Any suggestions?
add an amp/sub if you want- i think these guys can help. also cant remeber who is was but a dude on the forum put soundtream speaks in the rear without changing headunit etc...<ul><li><a href="http://www.linkmeup.com/">http://www.linkmeup.com/</a</li></ul>
turn the BOSE mode off. There are line outs on the back already so you can run aftermarket speakers thru an amp. You will need an adpator to access the line outs though...$9 from Crutchfield.
That's defined by the Bose amp and the bose speakers. Turning it off would not be a requirement to upgrade the system, more of a recommendation.
Bogaat
12-07-2002 06:29 AM
Ant 12v
04-18-2002 07:10 PM
Mackaloo
12-20-2001 03:42 PM
