Can I put an APR chipped M box ECU into my A4 that had a CH box?
#24
Revs rise and fall more quickly. It makes it easier to rev match and the lighter wheel looses less
to inertia. It makes the car slightly quicker. The down side is that you can get some 'rattling' at idle due to the lighter flywheel not averaging the acceleration impulses as much as the heavier OE wheel will and the idle can get a bit lumpier for the same reason. The OE wheel is also a dual mass ... there is an elastic membrane between masses that stretchs as the cylinders accelerate the crank on each fire. This also smoothes the rotation at idle and just off idle. A LWFW should be couple with a sprung hub clutch to help do this same thing.
my2000apb MEGABOOST
04-18-2007 11:54 PM
JVond
08-02-2002 06:13 AM
DenverA6
11-08-2001 02:53 PM
