Can someone confirm the hex wrench size needed for ATF fill plug
for some reason most posts in the archives have people using large bolts instead of the proper tool.
But after you change your fluid, keep an eye out behind you around midnight. After I changed my fluid, on my way home from work that was when i got rearended in the '97...
Here's a great site for reference. The lower half has step by step instructions.<ul><li><a href="http://www.taligentx.com/passat/maintenance/atfchange/">ATF & Filter Replacement</a></li></ul>
draining the fluid. some people drain the fluid and then find out that they cant get out the filler plug... be aware of that
jpjmustang
34
05-19-2011 08:08 AM
Mr Paul [T-28]
05-30-2007 02:49 PM
EastSidinA4
10
02-20-2007 09:53 AM
