Can someone explain what this fault code means?
16395 Cam-Timing Adj. Bank 1, Advance Setpoint Not Reached
35--10 --- Intermittent
The car feels a little sluggish lately, so I plugged in the computer and used up VAG-COM to perform throttle adapation. Before I performed the throttle adapation, I checked the engine fault code and the aforementoin fault code appeared. I cleared the code, performed throttle adaptation and did a short run with the car. Used VAG-COM to check after the drive and no more fault code. FYI, car is APR chipped.
A4TURBO2 // TMK
10-28-2003 12:35 PM
