Can someone help me out with these codes ...
18047 - Accelera.Pedal Pos.Sensor 1+2 Range/Performance
16622 - Manifold Pressure Sensor Signal Too High
18320 - Pressure Sensor Brake Boost - Short to Plus
16490 - Manifold Abs.Pressure or Bar.Pressure Range/Performance
I got these codes after trying to repair (yet again) my MAF wiring harness. New wiring is resoldered and hooked up correctly and now I get these codes and the car won't start.
When I jumped my car ... I got an EPC light on and also FYI I can't do a throttle adaptation using VAGCOM (Block 063) with the ignition turned on ... I get an "ERROR" in Green.
Any ideas? Car hasn't been running for a month
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
QuiksilverS4
08-02-2009 03:16 PM
PMrider
05-27-2008 06:47 PM
crabman
10-20-2002 08:38 AM
