can someone tell me what fault code 17544 means..thanks.
If it has to add or take away more then 10% I think it is, then it will throw a code. This happens if your maf is going bad, your injectors are getting plugged, bad plugs or the chip you have does not run enough fuel.
First...u need to give us a little more info...
By the "Bank 1"...u must have a V6? Right? Any mods chips, how many miles, what year?....
This means that something is not working right on the one side of the engine(3 cyl)
I don't know what it means, however, process of elimination....
The problem is only on the 1 side of the engine. U must find what sensors and how many sensors are located on each side. For example, do u have 2 fuel pressure regulators? Do u have a split fuel injection rail....
U have 2 knock sensors(1 per side)
U have 4 o2 sensors(2 per side)
U may have a leak on the exhaust manifold??
Please take note...taking shots in the dark here. I'm not familier with the V6 as much as I'm with the 1.8t....
good luck,
DG
good luck,
DG
cparke
12-27-2008 06:16 AM
boogs
08-12-2005 10:53 AM
