Can these Momo pedals be made to fit?
My roommate has these on his M3, and I really like them. They might make heal-and-toe a lot easier. I'm guessing the accelerator pedal can be attached to the original at the top, and the bottom part just pivots from the floor.
<img src="http://sportscar-parts.com/scaimages/graphics/mmle1111pedals.jpg">
to make it safe and functionally sound...
the audi's go pedal travels much differently than the bimmers as it wasn't designed for a floor hinge design like the bimmer. The bimmers have a mechanism that anchors or pivots from the floor and applies to the pedal arm that makes it work right.
If you adapt this to the audi, you would have to make some kind of hinge or anchor for the pedal on floor and also modify the upper part of the pedal that's directly connected to the electronic actuator or whatever so that release of the throttle will have no risk of getting stuck or else you'll have a safety issue... wabammm!!![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Interesting thought though.... it sure would make heel-toeing much easier since it is virtually impossible to it effectively with the stock pedals.
ruknd
02-28-2006 06:43 PM
starting ...
02-03-2006 06:39 PM
