Cant remove stock DV little help?
the clamps all the way? A little rubber lube or plastic/wooden pry tool helps to unseat the hoses. Or even rubbing alchol helps.
if your really having trouble just remove the airbox, that the hose off the turbo, pop the hove off of the holder towards the bottom of the engine (youll need to take the areo tray off with 6 screw i think, ittl drop down easy) and either take it off from below or up top. i Took mine off from up top, itll go back together alot easier :-) just keep taking off easily removable hose till you can get a good grip and yank. I also bought some new small silicoln line when i did mine and repleced the line from the top of the dv to the manifold and from my 5 bar fpr to the manifold when i replaced my factory fpr. it should be too much of a pain if you give yourself enough room to work.
eigenvector
9
05-13-2006 07:53 PM
Rocket3004
11-26-2005 09:18 PM
HACK THS
10
08-09-2004 09:02 AM
1bads4
21
04-13-2004 07:14 AM
