Can't shake this P1128 code...VAG COM scan inside.
VAG-COM Version: Release 607.3-UD
Control Module Part Number: 4B0 906 018 Q
Component and/or Version: 1.8L R4/5VT G 0006
Software Coding: 07251
Work Shop Code: WSC 06325
4 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 35-10 - - - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 35-10 - - - Intermittent
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
Readiness: 0010 1001
Address 01: Engine
Part No: 4B0 906 018 Q
Component: 1.8L R4/5VT G 0006
Coding: 07251
Shop #: WSC 06325
3 Faults Found:
P1128 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
Readiness: 0000 0000
here are the individual groups..
Group 032
At idle additive
-10% .. +10%
-0.9
P.throttle mult.
-10% .. +10%
25
Group 003
Idling speed
740-920 rpm
800
Air mass drawn in
2.0-4.5 g/s
2.64 <-- this stays around the 2's at idle
Throttle valve angle
0.2-4.0 %
3.1 <----- 3.1 to 3.5 range at idle
Ignition angle
0-12° BTDC
15 <------------ ranges from 15 to around 13
Group 115
Engine Load
12.75-175 %
17.3
Specif. charge press.
1350 - 1750 mbar
990
Actual charge value
Differ. max. 100 bar
1010
Group 113
Air Pressure
500-1200 mbar
995
Group 115
1350 - 1750 mbar
990
Actual charge value
1010
from reading the FAQ and doing a search i've replace the two vacume lines that are the ends of the intake manifold..one was for fuel pressure regulator.
there is another hose that goes from under the intake manifold that goes to it looks like N75 valve....i haven't changed that yet..(just found this line today)
i'm also going to change the L hose since i read that this is usually brittle...but the old doesn't appear to be leaking.
i changed the plugs and the old ones came out looking ok. slight white residue.
also changed the fuel filter since it really needed it. also did the air filter just in case.
the front O2 sensor was replaced recently also.
i read that other possible parts...
MAF
N75 valve
before i dump more parts into it anyone have any suggestions?
after i reset the light the next morning the car was having a very rough idle (i assume misfire) and it actually stalled.
when the car is warm it appears to run "ok" but not sure if there's a boost leak or something that i just don't know.
sorry for the long post...hopefully all this data helps.
Thanks!
Dan
4 Faults Found:
P1128 - 35-00 - -
Address 01: Engine
Coding: 07251
Shop #: WSC 06325
3 Faults Found:
P0411 - 35-00 - -
Group 032
At idle additive
-10% .. +10%
-0.9
P.throttle mult.
-10% .. +10%
25
Group 003
Idling speed
740-920 rpm
800
Air mass drawn in
2.0-4.5 g/s
0.2-4.0 %
Ignition angle
0-12° BTDC
Group 115
Engine Load
12.75-175 %
17.3
1350 - 1750 mbar
990
Actual charge value
1010
Group 113
Air Pressure
500-1200 mbar
995
Group 115
1350 - 1750 mbar
990
Actual charge value
1010
MAF
N75 valve
Thanks!
Dan
boostbuddy
VAG-COM Discussion
12-26-2007 11:53 AM
boostbuddy
12-23-2007 11:09 PM
Stupid CEL, these same codes keep coming back....time to fix the problem instead of clearing the cod
DM-S4
04-14-2006 02:05 PM
mpwolf
17
07-15-2003 09:48 PM
