Car is feeling a bit drifty on the highway over bumps, lighter steering left then right + clunking
when going over say, a speed bump at an angle or turning into an inclined driveway off the street. Seems less stiff all around.
I can say I have been scraping some snow/ice under the car. No major pot holes or large ice chunks.. The clunk seems to be coming from the drivers side front.
Sway bar links? I have yet to get the car in the garage to inspect it with the weather being so bad.
Thoughts?
Thoughts?
TRE's are getting pretty old.. I would say 6 years. They are the pretty beefy ECS TRE's
Swapped in a new control arm kit 3 years ago and left the TRE's alone.. they looked real good.
Never had a TRE clunk before. I'll have to get the car up pull a wheel and inspect a bit. Same goes for the sway bar links.
It's not really "drifty" in the tre sense.. more or less floaty..
for example.. driving 70mph on the highway over a bump for a bridge. The car floats a bit side to side.. almost feeling less rigid then it has been. Which leads me to believe its a sway bar issues.
ok. duh, the car kind of "sways" more then it should. sheesh. *slaps own face*
are hyperco springs pigtail like OEM springs? did they come with new upper spring perches?
or, did you have to fabricate / cut away some of the rubber to make the springs fit?
the rubber could be worn out.
I had to cut away rubber on mine to make my STaSIS coilovers fit and I've been wanting to replace them since I think that's where some of my clunkyness comes from. maybe when I have to do control arms, I'll replace them. I wonder if STaSIS makes upper spring perches (or did).
how old is the suspension, in general? shocks might be going out.
hyperco's are seeing some age and are OEM in fasion.. the shocks are a few years old.
Everything seemed in order a month or so ago when Hansen and I removed the suspension and raised the car (grooved Bilsteins).
I'll have a better idea when I can get the car up to poke around.
bac2h
05-12-2006 08:05 AM
fatboyq
09-07-2005 10:01 AM
markbradford
11-19-2003 04:32 AM
egp320i
10-08-2003 06:30 PM
Tept
23
08-10-2003 11:48 AM
