Car hiccups and stalls...I did SEARCH a lot and still no luck figuring it out
Hi guys I'm new to the forum (1st post). I have a 2000 1.8t (ATW) quattro. I have seen many other people with symptoms similar to mine but I still can't fix the damn car.
I have new K&N air filter
I cleaned the injectrs with the Red Line FIC
I have new spark plugs
The first few times when the car died there were no DTCs.
I VAGed it yesterday and I got a couple of codes on the throttle body - "Lower stop not reached" and "Adaptation not started". When I turned the ignition on the throttle body was going crazy opening and closing and my CEL and EPC lights were blinking.
So i taught it was the TB, and i took it off and I cleaned it. I put it back on and.... no change. Still crappy idle (from timt to time) and the car stalled again today. I VAGed it again and I got "Error in Mapped Cooling System (check Temp-Sensor and thermostat) I have read that the sensor can send weird signals to the ECU and cause rough idle but no stalling. Thermostat is new as well.
Some people change the coilpacks and oxygen sensors but I don't think that is my problem. OS will throw a code right? And i doubt a bad coil on 1 cylinder will be anough to stall the car.
What do you guys think?
Hmm...
if you just installed the K&N. That could be your problem. They come very heavily oiled. It's possible you fouled your Maf with excess oil.. 2 options to remedy this. 1) clean it b)buy a new one. In the meantime... try disconnecting it and starting it. good luck
Here is the VagCom log
Scan 2
VAG-COM Version: Release 504.1-D
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 17 25 35 45 55 56
Address 01: Engine
Controller: 4B0 906 018 P
Component: 1.8L R4/5VT G 0006
Coding: 07201
Shop #: WSC 06335
3 Faults Found:
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 1000
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
1 Fault Found:
01200 - ABS Valves Supply Voltage
35-00 - -
Address 08: Auto HVAC
Controller: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D57
Coding: 00140
Shop #: WSC 06335
No fault code found.
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8D0 920 980 C
Component: B5-KOMBIINSTR. VDO D11
Coding: 02244
Shop #: WSC 00000
Address 35: Centr. Locks
Controller: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16140
Shop #: WSC 06335
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00012
Shop #: WSC 06335
Address 56: Radio
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00115
Shop #: WSC 06335
End --------------------------------------------------------------------------------------------------
Scan 1
Control Module Part Number: 4B0 906 018 P
Component and/or Version: 1.8L R4/5VT G 0006
Software Coding: 07201
Work Shop Code: WSC 06335
5 Faults Found:
17973 - Throttle Actuator (J338): Lower Stop not Reached
P1565 - 35-10 - - - Intermittent
17987 - Throttle Actuator (J338): Adaptation Not Started
P1579 - 35-10 - - - Intermittent
16988 - Internal Control Module: RAM Error
P0604 - 35-10 - - - Intermittent
P1602 - 35-00 - -
P1606 - 35-10 - - - Intermittent
Address 01: Engine
Coding: 07201
Shop #: WSC 06335
3 Faults Found:
P1606 - 35-00 - -
Coding: 0273004284
Shop #: BB 24334
1 Fault Found:
35-00 - -
Coding: 00140
Shop #: WSC 06335
Coding: 02244
Shop #: WSC 00000
Coding: 16140
Shop #: WSC 06335
Coding: 00101
Shop #: WSC 06335
Coding: 00012
Shop #: WSC 06335
Address 56: Radio
Coding: 00115
Shop #: WSC 06335
Scan 1
5 Faults Found:
P1602 - 35-00 - -
