car idling at 3000?!
i recently bought this car which had egr code, throttle position sensor, and 02 sensor. i cleaned the egr and i vacuum test it and it works. i also cleaned the 02 sensors and replaced the throttle body sensor. i just started the car up and it was idling around 2 then after a minute the check engine light came on and the car went up to 3000 rmp and stayed there even after it was warmed up.....helppp
its a 1997 a4 quattro 2.8 .... i just got back from autozone and the codes read p1101 definition heated oxygen sensor bank 1 sensor 1 sensor circuit voltage too low - air leak explanation open or short circuit condition probable cause poor electrical connection, exhaust leak near 02, failed h02s11......the second code reads p0138 definition heated oxygen sensor bank 1 sensor 2 sensor circuit high voltage explanation rich air/fuel ratio probable cause short circuit condition faulty h02s12
i dont see how oxygen sensors could cause such a high rpm....i was thinking the map sensor but nothing popped up for that....
i found a hose leading nowhere....can this be the problem? where does it go? http://s240.photobucket.com/albums/f...dilosehose.jpg
originaliowan
10-24-2019 07:24 AM
audiquattroduo
11
11-13-2008 02:46 AM
Seabeast11
03-10-2007 05:06 PM
